This command is a macro command that can be used to disable all AVB protocols on the given ports. It is equivalent to issuing the following three commands:
disable mvrp ports [port_list | all]
disable msrp ports [port_list | all]
disable network-clock gptp ports [port_list | all]
| avb | Audio Video Bridging. |
| port_list | Port list separated by a comma or "-". |
| all | All ports. |
Disabled.
Use this command to disable all AVB protocols on the given ports.
disable avb ports all
This command was first available in ExtremeXOS 15.3.
This command is available on all ExtremeSwitching Universal switches that support the AVB feature.
